It is currently Fri Aug 15, 2025 8:20 am
 Post subject: Laser cut fret slots
PostPosted: Thu Dec 11, 2014 2:55 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends
i have a laser cutting machine nearby my locality
yesterday i went and checked whether it can cut wood or not and it does very fine job
so im planning to cut the fret slots of 0.55 mm wide and 2.5 mm deep
is it advisable to cut the slot with laser machine?
what are its advantages and disadvantages?
 Post subject: Re: Laser cut fret slots
PostPosted: Thu Dec 11, 2014 3:08 pm
Never heard of anyone doing that. But, give it a try and let us know how it goes!
PostPosted: Thu Dec 11, 2014 3:17 pm
First name: maarten
Last Name: van guyse
City: heusden-zolder
Zip/Postal Code: 3550
Country: belgium
funny you mention this. I always mark the position of the frets with a laser cutter. Actually I did 3 fretboards earlier today. [:Y:]
I don't actually cut the slots itself (at least not until now). Probably it can be done if you want to invest the time to find the optimal settings in laser power and traveling speed of the laser.
But even then, I find that even relatively light differences in the colour of the ebony I'm using can result in quite a big difference in the depth of the cut.
Anyway, feel free to experiment... ;)
PostPosted: Thu Dec 11, 2014 3:23 pm
First name: Chuck
Last Name: Rogan
City: New Hartford
State: Ny
We have a laser cutter in the tech shop of my school. When cutting hard wood it usually leaves a burnt edge, this might affect how well the fret barbs hold. In addition it will cut deeper in the less dense wood than it will on the hard grain lines. I think you might see slots of inconsistent depth.
PostPosted: Thu Dec 11, 2014 5:01 pm
corrected
Martin is using lasers but not in this process
this is done with endmills
PostPosted: Thu Dec 11, 2014 5:13 pm
I'm curious since I have no experience with lasers and wood working what stops the beam from cutting all the way through the board? Also is the beam a beam or a pulse and regardless what's being attenuated to control depth of cut or is it a duration thing?
Inquiring minds wanna know please?
PostPosted: Thu Dec 11, 2014 6:32 pm
it is amazing what it can do and yes depth control is part of the design.
I edited original post
end mills ( upcuts ) are used.
PostPosted: Thu Dec 11, 2014 6:52 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
In the hands of a professional, I'm sure it would work just fine.
Alex
These users thanked the author Alex Kleon for the post: dzsmith (Thu Dec 11, 2014 7:28 pm)
PostPosted: Thu Dec 11, 2014 9:11 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I have a laser cutter & I'd say no way unless you were cutting some sort of perfectly homogeneous material.
The power or the beam is constant so the properties of what you are cutting must be constant too if you are trying to cut to a particular depth. Cutting all the way through is a much easier matter.
Different woods & materials behave differently & not as you'd expect. As an example, it's easier to cut Bocote than Koa although Koa is much softer & less dense.
Kevin Looker
I'm not a luthier.
PostPosted: Thu Dec 11, 2014 10:04 pm
Maybe Martin is cutting those dark matter fretboards with it.
PostPosted: Fri Dec 12, 2014 1:14 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I tried this a couple of years ago, but gave up in favor of using a CNC with a 23mil bit in it.
Kevin has is right IMO - the depth of the cut is too dependent on the consistency of the material being cut.
Even on the same piece of wood (ebony), I found laser-cut fret slot depth to vary too much (aimed for 75mil deep, got 30 to 100mil approx).
Maybe on more uniform density/grained woods it might work, but I found the CNC to be a much better solution.
FWIW, I also use my laser to make Ryan-style A4 kerfed linings (under license). Mahogany seems to be fairly predictable as far as laser depth-of-cut is concerned, but I still do test cuts to get the speed/power right before committing to a new batch of wood.
Dave F.
Cambrian Guitars
These users thanked the author Dave Fifield for the post: Pmaj7 (Fri Dec 12, 2014 1:44 am)
PostPosted: Fri Dec 12, 2014 7:36 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
bluescreek wrote:
Martin has been doing this for years
John, in a post on the UMGF on 09/26/14 you stated (in reference to the Martin fret slotting process)
Quote:
they do use a small bit and they have a way off cooling it. and yes it is cut in passes but it won't take long. They have a few machines set up for this. That is not the bit they use , they use a standard upcut endmill that cuts a .023 slot. I think they were also playing with a laser machine.
Are you now saying that the entire production of the Martin fret slots is done by laser? I find that very hard to believe . . .
PostPosted: Fri Dec 12, 2014 8:20 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I run a laser cutter at my work and I know how it works.
In the time it would take to set in all up to cut at the right depth and the time you wait for the machine to do it you could already have cut 2 boards by hand if you have a jig set up.
Laser cutters are great for making templates and jigs. for example I made a nut slot guide where all the increments are off-set by 0.1mm. It's fantastic for headstock templates or bracing layout guides etc.
You could spend your time better making a jig to accurately and consistently cut fret boards by hand.
Martin may do it (I allso find it hard to believe unless the finger boards are some type of acrylic) but they would have a super-duper laser cutter that small businesses can't afford and they are doing production lines.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Fri Dec 12, 2014 8:47 am
I tried this several years ago. Before I figured out a good method of cutting multi-scale frets slots.
The results were very poor. Not only was the cut uneven because of the different color in the ebony, but by the time it got deep enough to render a good slot, the top of the slot was "V" shaped. After one finger board was ruined by this, we experimented with different settings and simply could not get a deep, narrow, homogeneous cut. I think blades/bits are the only way to do it well.
PostPosted: Fri Dec 12, 2014 10:23 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Zip/Postal Code: 16323
I wonder if the laser is used to cut their Richlite fingerboards? that seems more consistent than ebony or rosewood.
My experience with lasers cutting organic material (surgical) is that depth of cut is a constant concern. I can't imagine a laser being more efficient, unless you have a "smart laser" that monitors the depth of cut real-time. But now yer talking BIG bucks! (as in LASIK technology, applied to lutherie)
PostPosted: Fri Dec 12, 2014 11:41 am
Martin changes this more often than you may think when something is available that works . I do stand corrected . End mills ( up cuts ) are still being used. They changed from a through slot to pockets slots a few years ago
PostPosted: Fri Dec 12, 2014 12:27 pm
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
What if you mounted the board on-edge? It would take longer, but should work, right?
PostPosted: Fri Dec 12, 2014 2:11 pm
First name: Hugh
Last Name: Evans
Martin uses lasers to print everything on the neck block. Fretboards are cut in a CNC process (not sure if they want to have that information disclosed it not, so I'll take the cautious route.)
Lasers are unpredictable, damaging, and slow when cutting wood. I wouldn't use them on a fretboard for anything beyond scribing lines to mark fret positions.
PostPosted: Fri Dec 12, 2014 2:41 pm
Martin does use the laser cnc to cut and profile the sides. It is faster that with conventional methods and there is no sawdust . They have a few laser machines as stated above one for the neck block and sound holes cutouts and they also use them for the back cross grained support and the bridge plates.
Not sure but I think they are using them for the backs also.
PostPosted: Fri Dec 12, 2014 7:33 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
The video I saw showed Martin using the laser to cut the fretslots. Even leaving a bit of wood uncut at the ends to actually bind the fb.
PostPosted: Fri Dec 12, 2014 10:43 pm
As John mentioned Martin uses CNC routers/milling machines to cut slots for their now standard "faux" bound finger-boards. As indicated above a standard .023" bottom cutting end mill will produce more consistent slots. Lasers are great for profiling since the depth is not an issue. I believe there is also a concern for the draft angle that is made by the laser (the sides of the slot would have very slight taper) I've had plenty of the new Martin finger-boards here in the shop there is no indication that the slots were burned in. Also laser cutting hardwood produces an awful odor and plenty of nasty fumes.
Ken Cierp
PostPosted: Sat Dec 13, 2014 2:36 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Have you got a link to this video ?
PostPosted: Sat Dec 13, 2014 7:44 am
Here's info about C F Martin slotting process from the actual tool manufacturer and Martin Engineers
http://www.sme.org/MEMagazine/Article.aspx?id=20187
Ken Cierp
PostPosted: Sat Dec 13, 2014 9:47 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
No.
The beam has a limited depth of focus - imagine it like an hourglass shape with the lens at the top of the hourglass and the focus point at the waist. A longer lens will give you a taller & wider waist and taller overall height. The depth of focus is nowhere close to the 2" you'd need to cut a fret slot from the side.
Kevin Looker
I'm not a luthier.
PostPosted: Sat Dec 13, 2014 11:21 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Murrmac the video was in a thread on this site. Sorry I don't remember which one. It was about safety?
Users browsing this forum: pullshocks and 16 guests
